Turn signals not working
Old Jul 31, 2013 | 10:52 PM
kjo1997's Avatar
kjo1997
Exclamation Turn signals not working
I just purchased a 2000 dodge dakota and it has many problems. one of them being the turn signals not working. I checked the lights and fuses, even bought a new turn signal switch and no luck. The hazards and everything else works, just the turn signals not working. what else could e the problem??
Old Aug 2, 2013 | 10:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Aug 2, 2013 | 10:49 PM
00DakDan's Avatar
00DakDan
Section Moderator
Do all the bulbs work when you put the hazards on? There are two bulbs each side on the front.
If so, have you changed out the combination flasher? Under the dash
Old Aug 11, 2013 | 04:53 PM
kjo1997's Avatar
kjo1997
I just bought the combination flasher. Hopefully this solves the problem. Just have to figure out how to take the dash out
Old Aug 11, 2013 | 05:37 PM
00DakDan's Avatar
00DakDan
Section Moderator
What do you mean, "take the dash out?"
You should be able to reach up there and get at it. If you want, pull off the 2 screws and the panel under the steering wheel comes off - gives you a lot more access.
