throttle body spacer
Old Aug 5, 2013 | 05:26 PM
DakotaPower3's Avatar
DakotaPower3
Default throttle body spacer
thinking of putting a throttle body spacer on my 3.9 any1 every put 1 on and if so how do you like it. and what brand did you use
Old Aug 5, 2013 | 06:08 PM
01dak3.9's Avatar
01dak3.9
They don't do anything so just save your money.
Old Aug 5, 2013 | 06:22 PM
Blacknights's Avatar
Blacknights
Don't waste your money, www.thefastman.com
Buy a bigger throttlebody
Old Aug 5, 2013 | 06:37 PM
User's Avatar
User
He has a 3.9, he can run a 5.2 or 5.9 throttle body as a performance mod, you can find them used for 20-50$.
Old Aug 5, 2013 | 07:02 PM
Blacknights
It's an automatic response, wasn't paying attention to that. But nowadays my junkyards have all been bought up and everything is now 3 times the price.
Old Aug 5, 2013 | 08:02 PM
User's Avatar
User
TB for 20$
http://www.dakotart.com/forum/showthread.php?t=27454
Old Aug 5, 2013 | 09:48 PM
DakotaPower3
i thought about going with the bigger throttle body wasnt sure if it would fit on a 3.9
Old Aug 6, 2013 | 04:10 AM
Blacknights
Originally Posted by User
I don't need one, I've bought a fastman a while ago. Thanks though
Old Aug 6, 2013 | 08:42 PM
woodeman's Avatar
woodeman
I see a lot of throttle bodies on Ebay for 5.2/5.9. If these are indeed compatible w/3.9 can anyone who has done the swap answer some questions? Is it a direct swap(no special fixtures or gaskets, etc. needed?) Does the computer throw codes? And most importantly, is there a noticeable improvement in the low end? I have a 2003 and it is a snail compared to the 94 w/the same engine that I drove for many years. I was really surprised at the lack of low end pickup. Thanks in advance.
Old Aug 12, 2013 | 09:43 PM
ahsnowlover's Avatar
ahsnowlover
I put a v-8 throttle body on my 3.9 and the only thing that I ended up having to change was the throttle cable from the gas pedal to the throttle body. As for the code I think I had one for the throttle position sensor for about 2 weeks while it relearned the settings after that haven't had a problem.
