drivers side window fell need part #
I have a 98 Dakota and my window has been rolling up crocked for months well today it fell so I took it apart and there are 3 plastic bushings that go in the window track and a stabilizer channel that the ***** on the end of the rods snap into I have looked online for the part number cannot find any
thanks d
thanks d
You won't find a part number for the plastic bushings, they don't sell them. You have to replace the regulator assembly.
You can try finding cabinet rollers that will fit. I did that for a bit but never could get them to stay in place for long.
If your window is a manual window I have a regulator that I'd sell you pretty cheap. One thing that I did was found a bolt that would fit in the regulator and bolted it to the frame and haven't had a problem since with it.
well I might have found a fix has worked for 2 days now
I used 3/4 shower door ball bearing rollers had to grind the od down a bit and drill out the studs on the arms but looks real good and they are sturdy
time will tell if it holds up but right now they look great
