manualtrans stuck in 2nd gear
Old Aug 16, 2013 | 12:45 PM
deck60's Avatar
deck60
Default manualtrans stuck in 2nd gear
98 3.9 5spd trans stuck n 2nd gear took top off trans tried a bar shifter will not move has any one had any luck getting this done - it has been stuck before but i have always been able to get it to move some and it came out but not this time
I was hoping it would last till winter then I can put in my new drive-train
Old Aug 16, 2013 | 05:01 PM
98DAKAZ's Avatar
98DAKAZ
Is It an AX-15 5 speed trans?
Are you low on oil in it?
Old Aug 17, 2013 | 10:46 AM
deck60's Avatar
deck60
I think it is a nv3500 it has plenty of oil you can see it from the shifter top I think Tuesday I am going to pull it and replace it with a junkyard special
Old Aug 17, 2013 | 11:11 AM
BlackTrim211's Avatar
BlackTrim211
what happens when you press the clutch down? what happens why you try to move the shifter with the clutch in and with out it?
Old Aug 17, 2013 | 11:33 PM
deck60's Avatar
deck60
nothing I even took shifter out and used a pry bar started it up and clutched it even tried with engine off and it will not move at all not even a little
