best performance upgrade?
#31
I have every bolt on you can get for the dakota 5.9. I would say the biggest gains i got came from my larger TB, GS motorsports headers, spintech true exhaust and mopar PC, cam and larger injectors.
Other parts:
Under drive pulley
msd coil
msd distributor
larger SP wires
HS drop spindels
street alt
viper eFan
1.7 HS rockers
m1 4bbl
ect, ect, ect..
In the process of finishing my 408T motor, its really the only way to go if you want to go fast and not feed off a bottle like a baby.
Other parts:
Under drive pulley
msd coil
msd distributor
larger SP wires
HS drop spindels
street alt
viper eFan
1.7 HS rockers
m1 4bbl
ect, ect, ect..
#33
Other parts:
Under drive pulley
msd coil
msd distributor
larger SP wires
HS drop spindels
street alt
viper eFan
1.7 HS rockers
m1 4bbl
ect, ect, ect..
Other parts:
Under drive pulley
msd coil
msd distributor
larger SP wires
HS drop spindels
street alt
viper eFan
1.7 HS rockers
m1 4bbl
ect, ect, ect..
#34
#35
I love my Dakota, id love it a lot better if I could fix the heating up problem.
#36
have you placed a mechanical water temp gauge? one of your water journals might be blocked? Thermastat could be stuck wide open/shut? changed the coolant? Changed the waterpump? Efan working? are you filling up with coolant than running low on coolant, if yes then you have a internal leak that you might need a new block, usally head gaskets are the problem. You block might be cracked, do you have coolant coming from the tail pipe?
#37
replaced the thermostat 3 times, has a 180 in It now, no mechanical guage available, coolant has just been changed as with a new waterpump, electric fan is working, it is not using any coolant, no water in oil so I don't think its a headgasket, nothing coming out of tailpipe. im leaning towards a radiator, I heard if you run strait water it can mess them up and when it overflowed on the interstate all I had was water. I will put a new radiator in it and then I will install a big electric fan.
#38
#39
