Window cycle problems
Old Sep 8, 2013 | 12:34 PM
coryannking's Avatar
coryannking
Default Window cycle problems
Hey everyone I'm a new member here and have a question that may have been asked and answered in the past. I have a 2003 Dodge Quad cab 4x4 and my issue is that the passenger and both back door windows can't be cycled up or down by their own switch. The drivers door switch works fine to cycle the glass up and down on it's door as well as cycling the other 3 windows. I've taken each door panel off to check for a pinched wire or broken wire,etc but everything looks good condition wise. It's like the window lock switch is on at the drivers switch panel. Hope someone can help me , thanks.
Old Sep 8, 2013 | 01:02 PM
00DakDan's Avatar
00DakDan
Section Moderator
Odds are the window lock switch is the fault. It supplies power to the passenger and both rear windows.
Check for 12 volts when the windows are unlocked. It used to be pin #8, the yellow wire. I don't know if they changed colors in '03.
Old Sep 11, 2013 | 09:43 PM
ryan1's Avatar
ryan1
If the switch ends up being the issue, you can check here http://switchdoctor.net best prices around.
