2wd to 4wd questions
Old Sep 23, 2013 | 06:23 PM
  #41
01dak3.9's Avatar
01dak3.9
I have heard of people retrofitting a Dodge speed sensor to a Ford 9 inch but I don't know how to do it.
Old Sep 23, 2013 | 06:31 PM
  #42
Tom A's Avatar
Tom A
Section Moderator
Fitting the sensor would be pretty straightforward. The hard part is the tone ring on the ring gear.
Old Sep 23, 2013 | 06:39 PM
  #43
01dak3.9's Avatar
01dak3.9
What does the tone ring look like?
Old Sep 23, 2013 | 06:44 PM
  #44
Tom A's Avatar
Tom A
Section Moderator
It's a big toothed ring that goes behind the ring gear and gives the speed sensor a signal.
Old Sep 23, 2013 | 06:57 PM
  #45
01dak3.9's Avatar
01dak3.9
So does the speed sensor have a gear on it too. I think I almost have it figured out.
Old Sep 23, 2013 | 06:58 PM
  #46
Tom A's Avatar
Tom A
Section Moderator
Nope. The speed sensor is a magnet.
Old Sep 23, 2013 | 07:14 PM
  #47
01dak3.9's Avatar
01dak3.9
I think I have figured it out!
Old Sep 23, 2013 | 08:05 PM
  #48
magnethead's Avatar
magnethead
When I was at the ford dealer, we machined new tone rings for the planetary dana 130's we were putting in trucks. Relocated the sensor and tone ring to the right rear hub. Actually was not that hard. The hard part was getting a machine shop to cut the rings.
Old Sep 23, 2013 | 08:17 PM
  #49
01dak3.9's Avatar
01dak3.9
That is easier than what I had in mind. I will have to talk to you about that later. What suspension should I use on the front? I want something that rides better and I don't particularly like rack and pinion. I will also lower the truck after the V8 swap.
Old Sep 23, 2013 | 08:19 PM
  #50
magnethead's Avatar
magnethead
The hard part about relocating the sensor and ring is getting the shop to cut it, and making the sensor clear the wheel rim and brake rotor. I may still have some pictures of it somewhere.
Radius arm or leaf spring is the cheapest depending what axle was set up for previously. 4 link is the hardest.
