Speedomoter not working
Old Sep 23, 2013 | 09:53 AM
angelicolar's Avatar
angelicolar
Default Speedomoter not working
So I had to pull apart the rear of my transfer case (nv231hd) to fix a broken seal and when i took it off i had to loosen the sensor with the green plastic gear that relays to your speedometer/ odometer and i forgot when i was putting it back together how it was positioned and now i get no reading on either my odometer or speedometer. Does anyone have a picture of this sensor so i can put it back to the correct position? thanks
Old Sep 23, 2013 | 01:02 PM
00DakDan's Avatar
00DakDan
Section Moderator
What year is your truck? Engine and transmission too please.
Old Sep 23, 2013 | 02:26 PM
angelicolar
97 5.2L and i think its the nv3500
Old Oct 1, 2013 | 06:33 PM
pigcatshiner's Avatar
pigcatshiner
Default 99 dodge dakota sport no speedometer
was told it was the sensors...Got the one for the transmission..
was told I had to get the rear one from a dealer? is this correct.
and do you think it will fix the problem? at one time it worked
after reaching 30 mph,then it quit all together...john
Old Oct 1, 2013 | 06:49 PM
00DakDan's Avatar
00DakDan
Section Moderator
By "the rear one" do you mean the speed sensor on the differential? It should be available from a parts store.
Old Oct 2, 2013 | 06:53 AM
pigcatshiner
yes on the diferrantioal the man said it was only had by the dealers ?
Old Oct 2, 2013 | 09:57 AM
00DakDan's Avatar
00DakDan
Section Moderator
Check Rockauto. They list quite a few.
Old Oct 3, 2013 | 07:01 AM
pigcatshiner
thanks for the info...I have to check it out....thanks
