Rapid ticking
Old Oct 1, 2013 | 10:31 PM
KVB's Avatar
KVB
Default Rapid ticking
Ok, when I run the fan for the heater, a/c, or vent from outside there is a rapid ticking sound that cycles on and off every 30 seconds or so. My a/c is not cooling, but the heater works fine. any thoughts as to what might be the cause of this sound, and how I might fix it? Thanks in advance for any thoughts and or suggestions.
Old Oct 1, 2013 | 11:40 PM
magnethead's Avatar
magnethead
compressor sounds shot. Not sure why it's running for the heater though.
Old Oct 2, 2013 | 06:32 AM
98DAKAZ's Avatar
98DAKAZ
If it happens running heat and cool A/C and only if the fan is running it sounds like some stuff got down into the fan area kind of like sticking a card in a bikes spokes so you get the cool clicking noise.
To clean it out may be very hard to impossible '
do you park under a tree or tall plant of any kind and get leaves so on dropped on the truck all the time?
It should clear up at some time on its own
