Replacing steering knuckle
Old Oct 6, 2013 | 11:00 PM
kingr00's Avatar
kingr00
Default Replacing steering knuckle
Can someone tell me what size the spindle/hub nut is on my 2000 2wd Dakota?
Old Oct 6, 2013 | 11:28 PM
01SilverCC's Avatar
01SilverCC
I am not sure on a 2000, but my truck is a 2001 2-wheel drive and my spindle nuts are 35mm. Maybe they would both be the same size, both being 2 wheel drive, and I doubt Dodge made any changes in axles from one year to the other.
Jimmy
Old Oct 7, 2013 | 12:21 AM
kingr00's Avatar
kingr00
Thanks Jimmy. It is probably the same. That's bigger than any socket in my tool chest...
Old Oct 7, 2013 | 08:37 AM
01SilverCC's Avatar
01SilverCC
I bought my socket at Advance Auto Parts. 1/2" drive and I believe it cost about $12.00 or $13.00. If you are able to drive your truck, maybe drive it to a parts store and pop the center cap off. Then ask if the store guys will let you take the socket outside to test-fit before you buy it. Or you can just buy it and if it is the wrong size take it back in the store for an exchange. Most parts guys will let you test-fit before buying.
A trick I learned on mine was to leave the wheels on, leave the truck on the ground in gear (or park) with the parking brake on, then pop out the center caps and put the socket on the nut with a 1/2" breaker bar. Then you can stand on the bar and break the spindle nut loose. Then jack the truck up and set it on jack stands and go about removing the wheel, caliper, spindle nut etc as usual. It's a lot easier if you have an impact wrench though..
Jimmy
Old Oct 7, 2013 | 10:13 AM
Brian in Tucson's Avatar
Brian in Tucson
If you have a Harbor Freight nearby, it will be about $5.
Old Oct 7, 2013 | 01:14 PM
01SilverCC's Avatar
01SilverCC
I checked HF when I bought mine, the largest they had was 32mm, if I remember it right.
Jimmy
Old Oct 7, 2013 | 02:28 PM
magnethead's Avatar
magnethead
a 1-3/8 socket should also fit snugly, I believe.
Old Oct 8, 2013 | 08:55 AM
98DAKAZ's Avatar
98DAKAZ
Do you already have a replacement knuckle?
They are very $$$ did you know that? new is around $900 if lucky you can get a used one
