My air cond compressor is rattling as the bearing is gone. It looks like I can run a shorter belt. Will the heat and still work ok? I was hoping to replace the compressor in the spring. does anyone have the belt number?
You have to physically remove the compressor for the non-AC belt to clear.
I now run a 89.5 inch 7 rib belt. No more rattle from the air conditioning compressor! The sticker under the hood shows a different routing to by pass a/c.
I can get a new Napa compressor for $183(here they are $475 new) just have to drive about 30 mins to get it, but that can wait until spring. A co-worker used to do A/C so he still has his gear, will charge me $50 to capture the 134A and recharge it once I have the new compressor in.
I just went though a compressor replacement. Had a shop do it, I didn't even stay to watch.
