power window problem
Old Nov 1, 2013 | 08:22 AM
imoace55's Avatar
imoace55
Default power window problem
2002 dakota quad cab 4.3 V8 lndividual power windows stations not working ONLY drivers PW station operable for all windows /all stopped same time suddenly
Old Nov 1, 2013 | 10:03 AM
00DakDan's Avatar
00DakDan
Section Moderator
I moved your post to a new thread.
Check that engine size if you would. 4.3?
A common problem is that the drivers side power window lock switch fails. Check for power on pin #8 at the drivers door - a yellow wire.
