No bus on odometer, blinking engine light -- Help please!
Old Nov 14, 2013 | 05:45 PM
  #21
phoenix9110's Avatar
phoenix9110
Do you know which years PCM(with the correct specs) will plug n play into my vehicle?
Old Nov 14, 2013 | 06:18 PM
  #22
00DakDan's Avatar
00DakDan
Section Moderator
It's not really plug and play. It should be programmed with your VIN and mileage and you need to match all options - including security.
At best you'd be limited to '01 or '02 due to wiring changes, etc. There are differences between the years so you really should get an exact match.
There are places online you can give them your information and they'll program one for you, then you just swap it out, fairly inexpensive (compared to Dodge).
Old Nov 14, 2013 | 06:28 PM
  #23
01SilverCC's Avatar
01SilverCC
http://autocomputerexchange.net is said to be one of the very best with rebuilding and reprogramming PCM's. I have read on other forums they do excellent work and stand behind their work and try their best to be sure you get the right part and it works correctly. They are in South Florida. OP might do well to at least check with them on a rebuilt PCM.
Jimmy
Old Nov 14, 2013 | 07:07 PM
  #24
phoenix9110
Will you check this thread out? I think I might be able to find a PCM from an 02 of like vehicle at my local junk yard, if it has the same basic specs. I don't need to pass smog right this second so i'm just trying to get this thing mobile.
Let me know on your opinions on this.
http://www.dakota-durango.com/forum/...d.php?t=149955
Old Nov 14, 2013 | 08:04 PM
  #25
00DakDan's Avatar
00DakDan
Section Moderator
The VIN won't keep it from running. Make sure everything matches.
If the PCM has security, and your truck doesn't, it won't work.
Do you have SKIM?
Old Nov 14, 2013 | 08:15 PM
  #26
phoenix9110
I found a PCM at a local junk yard in my exact truck BUT its an 00 instead of an 02. Understanding wiring changes for certain things, will this have any effect on it for just doing what I need it to do?
No SKIM
Old Nov 14, 2013 | 09:32 PM
  #27
00DakDan's Avatar
00DakDan
Section Moderator
The computer bus is different in '00, 2 wire, not the ONE wire you have in your '02.
It is NOT compatible, some pinouts are different.
You are limited to '01 or '02 at best. Even an '01 may not work but the wiring is the same.
Old Nov 14, 2013 | 10:05 PM
  #28
phoenix9110
I have access to a 2001 Dodge Van 3.9l PCM. Is this the same single wire PCI bus?
Last question, I swear!
Old Nov 14, 2013 | 10:34 PM
  #29
00DakDan's Avatar
00DakDan
Section Moderator
I don't know. There were differences between a Ram and a Dakota, just saying...
Old Nov 14, 2013 | 10:42 PM
  #30
phoenix9110
I only ask because of that previous thread I posted about the dodge van and the durango swap.
I'm at the point where I desperately need it to run...With cluster working. So I'm just really hoping that as long as its PCI and my 3.9l gas engine, that its going to start up.
