I got a 97 dakota 2.5 5spd tune up
Old Nov 17, 2013 | 01:14 PM
DurdyGP's Avatar
DurdyGP
Default I got a 97 dakota 2.5 5spd tune up
Whats everyone running as far as plugs n wires I use champion right now its copper my oil is Castro filter is fram but I got the kn do to the store not haven the TG16 wires wow its been so long I forgot let me know what works for you
Old Nov 17, 2013 | 01:28 PM
98DAKAZ's Avatar
98DAKAZ
Bosch iridium fine wire plugs Mobil 1 oil and filter with a wix air filter work great by me but things depend on what weather you are in I'm in Hot Arizona but my Dakota runs fine with the same setup every winter if you call that winter that is.
I run accel 8mm hot wires good wires so far been 7 years with them no problems.
Old Nov 17, 2013 | 01:41 PM
98DAKAZ's Avatar
98DAKAZ
Are you running with a big 62mm throttle body if so that could be the problem or the idle set screw is off you may need to adjust it I had to do that to get my Idle correct as I accidently over adjusted it.
Its easy to adjust the set screw
Have you checked for any air leaks
Old Apr 8, 2014 | 05:45 PM
DurdyGP's Avatar
DurdyGP
Default wow bosh is it
So I put the bosh iridium plugs in what a difference it runs so smooth now the idel is a little high but wow I was burning half a tank to work now im buring a little less then half there n back Thanks for the Tip doggie
Old Apr 8, 2014 | 05:58 PM
98DAKAZ's Avatar
98DAKAZ
Thumbs up
They also stay super clean two years pulled one out still looked new and shinny
