03 Dakota 4x4 Clicking on dry pavement
Old Dec 9, 2013 | 01:28 PM
sgroves1121@yahoo.com's Avatar
Default 03 Dakota 4x4 Clicking on dry pavement
We've had a bit of a snow and ice storm so using my 4x4, I noticed it was clicking on the right front when turning right from ice to dry pavement. Any suggestions? Is that a sign of the CV going out?
Old Dec 9, 2013 | 04:33 PM
sxrsil3nt's Avatar
sxrsil3nt
Clicking while turning is definitely a sign that your CV is going.
I'd peak underneath and see if you see the boot ripped, if so its likely theres your culprit.
Old Dec 9, 2013 | 06:00 PM
magnethead's Avatar
magnethead
keep in mind that 4x4 is not designed for use on dry pavement.
Old Dec 10, 2013 | 04:36 PM
00DakDan's Avatar
00DakDan
Section Moderator
I moved this thread into the proper forum.
Clicking can definitely indicate the CV joint failing but, as Magnet said, you shouldn't be using 4wd on dry pavement.
Old Dec 10, 2013 | 05:17 PM
modlite52's Avatar
modlite52
what about the 4x4 's that are full time?? mine has 4lolock, neutral, 4 wheel drive, 4 hiloc?
Old Dec 10, 2013 | 06:09 PM
00DakDan's Avatar
00DakDan
Section Moderator
Full time 4wd has no such restrictions about dry pavement. Your transfer case allows for the different speeds, front vs. rear, when turning. Not so with the part-time systems. That's why the part time systems bind when turning. It's very hard on the drivetrain.
