00DAKDAN, or any one else is welcome
Old Dec 15, 2013 | 10:33 AM
modlite52's Avatar
modlite52
Default 00DAKDAN, or any one else is welcome
Dan, I think I have my heat fixed, but in the process I must have knocked a wire loose. my airbag light is now on. my ? is what & where is wire going to pass side air bag? the drivers side is still hooked! thanks in advance
Old Dec 15, 2013 | 11:00 AM
00DakDan's Avatar
00DakDan
Section Moderator
Check your connections - the airbag system will have YELLOW connectors. There is one just under the steering column for the drivers airbag.
One more for the passenger airbag - yellow. From there it goes directly to the airbag control module.
Check your horn works too. Maybe the clockspring got damaged.
Old Dec 15, 2013 | 06:04 PM
modlite52's Avatar
modlite52
thanks Dan, horn works. will have to look at airbag module on pass side. drivers side wires are hooked. hope it's not clockspring,just replaced that when I got truck 2 months ago
