shock touching upper a arm?
Old Dec 21, 2013 | 04:33 AM
dakota5.9's Avatar
dakota5.9
Default shock touching upper a arm?
Got to looking when i put a new drivers side cv shaft in the ny shock was touching the upper a arm. My new cv shaft blew out after 1000 miles. It has the t bars cranked with skyjacker shocks, are the suppose to be touching the aarm and would that have anything to do with ny cv shaft going out so quick?
Old Dec 22, 2013 | 03:30 PM
jpayne80's Avatar
jpayne80
As long as the control arm is not hitting the shaft of the shock it should be ok. My KYB shocks have the metal cover rather than the rubber boot and my control arm hits it a bit from the torsion lift.
As for the cv shaft going bad it is probably more due to the stressed angle of the cv shaft from the torsion lift.
Old Dec 22, 2013 | 11:53 PM
dakota5.9's Avatar
dakota5.9
Yea its under warranty still just a pain to change. Anyone know the torqe specs for the axle nut?
