3.9 to 5.2 swap help needed.
Old Jan 15, 2014 | 03:07 PM
yetavon's Avatar
yetavon
Default 3.9 to 5.2 swap help needed.
Been searching for answers and still need some help, or confirmation.
I have a 97 Dakota SLT ext-cab v-6 auto 4x4 with 272K on it. Half of the 3000k a year it travels is pulling a 3500 Lb camper. Motor is weak and on its last legs. have been looking and researching about replacing it or stepping up to a V8.
I have found a 5.2 for $400 or $500 with the PCM, harness and exhaust. Its from a 99 Ram reg cab 2WD.
Doubt the exhaust will swap, but parts may be usable.
PCM? The more I read the more confused I became as to whether it will work, I can get the stuff to add 2 injectors to the existing harness.
The dreaded transmission question. Any opinions about how well the trans will hold up to the extra 55HP/75FtLbs torque?
Anything else I need to consider?
Thanks for any and all info and help.
Darrin
Old Jan 15, 2014 | 03:53 PM
00DakDan's Avatar
00DakDan
Section Moderator
The 5.2 itself will bolt in. The transmission, how long it lasts depends upon how you drive it. You could certainly leave it in until/if it fails.
The PCM, don't know. A Dakota is not a Ram. There are some differences and they also vary between the years. You would probably do better with a '97 5.2 pcm but if the PCM has 3 connectors it may work. You will need a harness.
Old Jan 16, 2014 | 12:41 AM
dodgeramguy85's Avatar
dodgeramguy85
I think you will need a pcm from a same year dakota not sure. As far as tranny it will hold up but towing a lot will for sure take it out. Heck even the 44re's that came behind the v8's werent that great.
Old Jan 16, 2014 | 10:29 AM
yetavon's Avatar
yetavon
Going the V8 route I have a lot of concerns with the transmission. It was a rebuild put in before I got the truck, and has worked fine, guess around 100K on it. when I dropped the pan and changed filter it was surprisingly clean.
Thinking I may just save some headache and nurse it along and find a full size extra cab truck.
Old Jan 17, 2014 | 10:04 PM
ahsnowlover's Avatar
ahsnowlover
I'm getting ready to do the same thing this summer, for the harness you just need to run the new wires for the 2 additional injectors and get a readout for the pin locations. As for the tranny I'm saving up for a 46re and have found them for around $1500.
