How to take out consoul?
Old Jan 31, 2014 | 11:18 PM
kickerman's Avatar
kickerman
Default How to take out consoul?
I am trying to put a cb radio in my above head consoul I can get the long outer peice off that holds cab lights but can't seem to figure out how to get the inner black plastic peice off image.jpg
Old Feb 1, 2014 | 06:03 PM
Toad's Ride's Avatar
Toad's Ride
From 2001 FSM
REMOVAL - OVERHEAD CONSOLE BRACKET
(1) Disconnect and isolate the battery negative
cable.
(2) Remove the overhead console from the overhead
console bracket. Refer to Overhead Console in
the Removal and Installation section of this group for
the procedures.
(3) Remove the headliner from the roof panel.
Refer to Headliner in the Removal and Installation
section of Body for the procedures.
(4) Remove the two screws that secure the front of
the overhead console bracket to the roof front header.
(5) Using a sharp utility knife, cut through the
double-faced tape that secures the rear flange of the
overhead console bracket to the roof panel.
(6) Remove the overhead console bracket from the
roof panel.
Old Feb 1, 2014 | 06:24 PM
98DAKAZ's Avatar
98DAKAZ
This may help with how to pull things apart without breaking things read the complete thing.
http://www.dakota-durango.com/forum/...ad.php?t=96058
Old Feb 2, 2014 | 08:21 AM
kickerman's Avatar
kickerman
Is there a way I can do take that black inner consoul off with out taking head liner off? To me it only looked like there two screws screw in so I took those out and still can't figure out how to pull that thing out?...
Old Feb 2, 2014 | 08:41 AM
Toad's Ride
Without breaking something, I don't think so as it double side taped to the roof which you need to cut. I haven't needed to do this, but my thoughts are removing the headliner prevents it from getting damaged which I cant imaging is a cheap replacement.
Old Feb 2, 2014 | 09:00 AM
98DAKAZ's Avatar
98DAKAZ
Call a local junkyard ask if they know they know how these things come apart if anyone they pull things like that off all the time.
Old Feb 2, 2014 | 01:46 PM
kickerman's Avatar
kickerman
Dose the part closest to windshield have the tape or the back of it?
Old Feb 2, 2014 | 06:47 PM
Toad's Ride
Look like toward the back of it (opposite the windshield side).
Here are two pics from the dis-assembly section.
1.
2.
Hope it helps.
File Type: jpg
File Type: jpg
Old Feb 3, 2014 | 05:25 PM
atthewmartin114's Avatar
atthewmartin114
i installed on in my truck you have to remover the head liner or you will rip the hell out of it. also why not use the comcole to install your Cb raido its strong enough to fold the radio just mount to the sides of it and drill the plastic and run the wiring or power off your lights in the concole it will maintain enough power to run the CB even under max load
Old Feb 3, 2014 | 10:41 PM
kickerman's Avatar
kickerman
Use the what?
