Electrical draw trans fuse
Old Feb 17, 2014 | 08:57 PM
RIFF-RAFF's Avatar
RIFF-RAFF
Default Electrical draw trans fuse
If I let my truck sit for 2 or more days without running, my battery drains to the point that the truck won't start. Using a multimeter to test the circuits, I came to find that my meter reading would drop by .08 amps when I pulled the 20 amp "trans" fuse. Is this enough of a draw to be causing my battery woes and what could be causing the draw? Thanks fellas
Frank
Old Feb 17, 2014 | 08:59 PM
00DakDan's Avatar
00DakDan
Section Moderator
What year is your truck Riff-Raff?
Old Feb 17, 2014 | 09:20 PM
magnethead's Avatar
magnethead
To draw 200 amps (enough to cause a no-start) in 40 hours is 5 amps drawn per hour, or 1/12th amp per minute. That's if my rough mental math is correct.
Old Feb 17, 2014 | 10:19 PM
RIFF-RAFF's Avatar
RIFF-RAFF
2002 4.7 auto
Old Feb 17, 2014 | 11:32 PM
magnethead's Avatar
magnethead
how much current draw do you show with the key off and removed, and doors closed (all lights and dingers should be off)? There should be well under an amp or two at most.
Old Feb 18, 2014 | 06:12 PM
dolittle's Avatar
dolittle
Here is a good video for parasitic battery draw.
