brake light
Old Feb 18, 2014 | 08:59 PM
moe7404's Avatar
moe7404
Default brake light
my 01 dak. the brake light came on. and the pedal is not feeling right. that's ok my mech can fix it. but my paper factory service manual does NOT say which brake fluid it use. DOT-2. DOT-3. DOT-4 i dont really know what number they are up to now. but my mech will. they did the same to tire numbers. i learned one number system for tires in high school the shortly after they changed the number system.
Old Feb 18, 2014 | 09:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
DOT-3 on the brake fluid. It should say it on the cap as well.
Old Feb 18, 2014 | 09:58 PM
moe7404's Avatar
moe7404
opps havent had time to check cap. my mom was in the hospital sunday and monday. she had high blood pressure. the hart test showed NO clogged veins. so we think she wasnt taking her meds. my #2 son is a medic in nat guard. he is great. some times i dont know which son i brag on the most my #1 son or my #2 son.
Old Feb 18, 2014 | 10:19 PM
00DakDan's Avatar
00DakDan
Section Moderator
Hope your mom is doing well.
Glad your sons are doing well too.
Old Feb 18, 2014 | 10:52 PM
moe7404's Avatar
moe7404
yes she is doing good. i could not do this with out my #2 son. thanks for your kind words.
Old Feb 19, 2014 | 06:17 PM
moe7404's Avatar
moe7404
well i did add brake fluid. DOT-3. the pedal is better. but still need my mech to look at it. i did see some brake fluid marked as DOT 3-4. thanks for the info.
Old Feb 19, 2014 | 06:25 PM
Dodgevity's Avatar
Dodgevity
Both will work, MOE. Anything else, does not work.
