rear axle question??
Old Feb 25, 2014 | 06:32 PM
Vladek's Avatar
Vladek
Default rear axle question??
is there any difference between 2wd and 4wd rear axles. came across a real good deal and i was trying to think of the work involved.
Old Feb 25, 2014 | 06:33 PM
Vladek's Avatar
Vladek
sorry. axles out of dakotas.
Old Feb 25, 2014 | 06:34 PM
ahsnowlover's Avatar
ahsnowlover
The main difference that I know if is that on 2 wheel drive the leafs are under the axel, where the 4 wheel drive are over the axel
Old Feb 25, 2014 | 06:37 PM
Vladek's Avatar
Vladek
so there is alittle cut and welding involved.
Old Feb 25, 2014 | 06:48 PM
Vladek's Avatar
Vladek
k. my next question is. would it be worth the extra work to make it work. i think it is a 9.25 (12 bolts on the cover plate). he only wants $150, and it would be a bump from 3.55 to 3.92. he also has a front 3.92 axle for 100.
Old Feb 25, 2014 | 08:58 PM
00DakDan's Avatar
00DakDan
Section Moderator
What year are the differentials out of?
Old Feb 26, 2014 | 08:45 PM
Vladek's Avatar
Vladek
it is from an 03.
Old Feb 26, 2014 | 09:21 PM
Tom A's Avatar
Tom A
Section Moderator
Originally Posted by Vladek
hmmmmm. wonder how much shipping would be? would that affect towing a trailer much? that and what would be involved in making the rear end 4.56?
It would probably tow great. To change the rear, you would need to replace the ring and pinion (and probably the bearings), but I think the differential carrier is the same. It's not really a do-it-yourself job unless you have experience and special tools. Around here, it costs anywhere from $200 to $400 per axle to have it done (labor only).
Just guessing at shipping, I would say about 50 bucks. It's really not that big or heavy.
Old Feb 26, 2014 | 10:02 PM
magnethead's Avatar
magnethead
Our crated transmissions are about $100 to UPS 2-day from Texas to Florida...
Old Feb 26, 2014 | 10:56 PM
00DakDan's Avatar
00DakDan
Section Moderator
it is from an 03.
Are these for your '97?
I ask because you probably have a Dana front differential in there now, not the C205F that '00 and later use.
There were some pretty substantial changes in the front suspension between '99 and '00.
