I got a 97 dakota 2.5 5spd tune up
Old Mar 2, 2014 | 08:06 PM
DurdyGP's Avatar
DurdyGP
Default I got a 97 dakota 2.5 5spd tune up
I need a coil truck is stock with Banks Headers what coil should I use does it matter im just trying to get as much punch out of this little motor as I can
Old Mar 2, 2014 | 08:14 PM
98DAKAZ's Avatar
98DAKAZ
Stock or OEM are good the aftermarket are better but $$ around $80 so stock $20 are fine.
Old Mar 3, 2014 | 07:39 AM
DurdyGP's Avatar
DurdyGP
But is it worth the up grade
Old Mar 3, 2014 | 09:12 AM
98DAKAZ's Avatar
98DAKAZ
Well I didn't notice anything different going to an excel coil I can go with a wider sparkplug gap so that's a plus. Its an improvement but I don't think you will notice any power from it. The OEM coil is considered to be a good hot coil.
I will also say aftermarket coils tend to burn out faster
Old Mar 3, 2014 | 09:17 AM
98DAKAZ's Avatar
98DAKAZ
Best upgrade for the 2.5 is good plugs a 4.0 jeep throttle body a true cold air intake and move the air temp sensor to the air hat and out of the intake manifold. A set of new O2 sensors will help.
Old Mar 3, 2014 | 05:26 PM
98DAKAZ's Avatar
98DAKAZ
A new project I'm starting is to ad in an oil catch can this is to stop oil from getting sucked into my intake manifold by the CCV breather system and to help cool down the hot air that its breathing down my manifold.
My choice is this model around $80
Old Mar 3, 2014 | 08:56 PM
Tom A's Avatar
Tom A
Section Moderator
I have an Accel coil on mine. I bought it because mine took a dump, not necessarily for more power (which is a good thing because it made absolutely no difference).
Old Mar 3, 2014 | 09:41 PM
magnethead's Avatar
magnethead
I have my breather tube completely unhooked on the valve cover side. The hose split and I just never replaced it.
