Taurus fan blowing fuses?
Old Mar 15, 2014 | 09:03 PM
  #31
that_guy's Avatar
that_guy
You might be able to cut most of the shroud off of the taurus fan, so that it's pretty much just round, and then mount it in the hole in the trucks shroud in a similar position to the clutch fan. Then the stock shroud should handle the air flow.
Old Mar 15, 2014 | 10:21 PM
  #32
magnethead's Avatar
magnethead
Originally Posted by dirtbiker
Awesome, thanks! One last question, are you just running without the bottom shroud? I noticed in your picture that it's not there, and if I could get away without it then it would make mounting a whole lot easier.
EDIT: Never mind, I decided I'm just going to do away with it.
yep, bottom shroud is el-gone-o.
