Blower motor resistor - 2000 Quad
Old Mar 24, 2014 | 03:18 PM
TheDad's Avatar
TheDad
Default Blower motor resistor - 2000 Quad
I've read as much as I can on the melted connector problem. I still have one question. How do you get to the connector to replace it? I can get to the resistor under the engine cowl, but can't get enough room to get the connector replaced. Looked under the dash and I can't find anywhere to get a hand up there to get the connector. Any hidden tricks?
Old Mar 27, 2014 | 10:53 PM
master tech's Avatar
master tech
Site Moderator & Tech
The connector should be under the dash on the passenger side, just below the glove box. There should be two 8mm/ 5/16 screw's holding the sensor into the heater box.
