Help Choosing Amp
Old Apr 5, 2014 | 12:44 PM
  #31
01dak3.9's Avatar
01dak3.9
I lied. I think this will be my last question. What kind of terminal do I use to run the speaker wire out of the sub box?
Old Apr 5, 2014 | 03:29 PM
  #32
01dak3.9's Avatar
01dak3.9
Nevermind on that last question. I am going to use threaded brass rod and brass nuts.
Old Apr 5, 2014 | 03:39 PM
  #33
01dak3.9's Avatar
01dak3.9
This is the right harness for my truck right?
http://www.sonicelectronix.com/item_...%5BIgnore%5D=1
Old Apr 5, 2014 | 04:57 PM
  #34
magnethead's Avatar
magnethead
both of mine, I ran the wires straight of the box, no interface.I actually "ported" the boxes and just ran the wires out the port- since both are down firing, it works well. But you're supposed to use a terminal cup.
Old Apr 5, 2014 | 07:16 PM
  #35
01dak3.9's Avatar
01dak3.9
When my dad gets home I'm going to order most of it. The amp is out of stock. So I will get everything except for the amp and will get the amp later.
Old Apr 5, 2014 | 08:21 PM
  #36
01SilverCC's Avatar
01SilverCC
Yes that is the harness you need. On the speaker wires exiting the box, unless you plan on taking the box in and out of the truck just drill a hole in the mdf some place where it won't show like on the back of the box. Drill a hole just slightly larger than the wire size itself, if using 14-16 gauge wire use a 1/4" drill bit. It will be tight but will pull through the hole just fine. Seal it off with silicone from inside the box if the speaker wire hole is too big.
Jimmy
Old Apr 5, 2014 | 08:48 PM
  #37
01dak3.9's Avatar
01dak3.9
Is it possible to get speaker wire with just a single wire or can I split the wire into 2 pieces?
Old Apr 5, 2014 | 09:03 PM
  #38
magnethead's Avatar
magnethead
most have a rubber or silicone jacket that you can split
Old Apr 5, 2014 | 09:22 PM
  #39
01dak3.9's Avatar
01dak3.9
Ok thanks for all the help yall!
Old Apr 9, 2014 | 06:40 PM
  #40
01dak3.9's Avatar
01dak3.9
Most of my stuff came to day except for the dash kit and the head unit an I still need to order the amp.
http://i1172.photobucket.com/albums/...pselnbtrry.jpg
