No, it won't matter which one you use. But to keep it simple just use the orange/white. Connect the orange white on the Metra harness to the orange/white on the deck harness.
No it's not needed for an aftermarket deck. I figured about the same, it must be something to do with OBD2 and/or the PCI bus. It's a good idea to tape it off or zip tie it back to the radio harness so it does not short out against the chassis of the new deck.
The blue/white on the JVC deck will connect to the remote on for your Kicker amp. The blue/white on the Metra harness does not get connected to anything. If you still had the factory Infinity amp in the system you would also connect the blue/white on the Metra harness to the blue/white on the JVC so it would turn on the factory amp and the Kicker sub amp.
