really short life on the water pump
Old Apr 19, 2014 | 07:34 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by podfish
in case anyone can confirm my thought it's the water pump bearing
https://www.dropbox.com/s/ejozpwqmfq...loudEngine.mp4
-- actually, I think it's NOT. Nice being home where I can do something, instead of posting from work by memory..
so anyway, I pulled the belts and started it. Pretty much the same noise as the video. Interesting noise, isn't it? I can't tell what it it...
Sounds heavier than a water pump. They usually make weird chirping noises. If the water pump was failing, you'd also see coolant coming from the weep hole. Remove the drive belt and spin things by hand to see if anything feels rough.
Old Apr 20, 2014 | 02:06 AM
98DAKAZ's Avatar
98DAKAZ
That sounds so familiar but just can’t remember what it was.
Old Apr 20, 2014 | 04:28 PM
magnethead's Avatar
magnethead
Sounds more like a squak squak type of rub than anything else. Have you checked your motor mounts?
Old Apr 20, 2014 | 10:40 PM
98DAKAZ's Avatar
98DAKAZ
I wonder if that's your timing chain slapping around maybe the tensioner for the chain died.
Old Apr 21, 2014 | 12:21 AM
podfish's Avatar
podfish
good ideas on the last couple of posts. Thanks - I'll check for both things.
