2004 power windows
Old Apr 27, 2014 | 09:30 PM
Uglyd's Avatar
Uglyd
Default 2004 power windows
Mines a 04 Dakota 2Dr. SLT. Window rolls up but not replaced motor & master control switch still same problem. Can roll either way with direct power, but not thru switch. Can't locate control module
Old Apr 27, 2014 | 09:31 PM
Uglyd's Avatar
Uglyd
Originally Posted by 00DakDan
Hi Ugly, Welcome to the forum.
What year/model is your truck? What is the problem you're having?
Trying to find control module, 04 Dakota salt 2 Dr quad cab.
Old Apr 27, 2014 | 10:05 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'll move these into a new thread.
I found this in the FSM:
On all models, the power window switch for the driver side front door window has an Auto label on it. This switch has a second detent position beyond the normal Down position that provides an automatic one-touch window down feature. This feature is controlled by an electronic circuit and a relay that are integral to the driver side front door power window and lock switch unit.
