Which wires go where?
Old May 14, 2014 | 01:03 PM
00DakDan's Avatar
00DakDan
Section Moderator
"Ground" is to bare metal yes. There are specific ground locations in the wiring diagram.
The "sensor ground" is NOT to bare metal. It is a specific terminal on the PCM, Connector 1 Pin 4.
Old May 14, 2014 | 11:33 PM
vimnjicki's Avatar
vimnjicki
Okay. Bypassed the old two-wire harness and went directly from the downstream O2 sensor to the PCM and the truck would turn over but not fire. it would cough but not fire. I wired it back and it started like a dream. Back to the drawing board, I guess. Thanks you guys, for your help.
