speed sensors
ok so in 98 or 99 dodge changed the way the speedo read in the dakota. my question is if i can switch my 97 over to this syster so i dont have to keep changing the yoke on the drive shafts when i change rear ends or front ends with my parts truck. i have done two rearends thus far and both iv had to change something. i would also like to use the newer 231 tcase without having to changed the input and output shaft and housing bc there different sizes. and bc the speed sensor is in my tcase on my truck. i do have a doner truck to get the wiring and module for the abs out of. i know i cant use the harness without some tweeking bc i have the 5.2 and the doner is the 3.9. but thats not an issue. please any information would be nice. i know assume the pcm will have to be flashed to accept the abs module but im not sure.
also for the first time i have a one wheel peal rear end in my truck and i hate it!!! WHO MAKE THE BEST CHEAP LOCKER FOR THE 8.25 REAREND!!!
