needing some help before I buy. thanks
Old May 27, 2014 | 03:18 PM
zachfloyd1105's Avatar
zachfloyd1105
Default needing some help before I buy. thanks
Will 18" rims with 225/60 on front and 235/65 on back fit on a stock 2000 dodge Dakota 2 wheel drive. No performance package if that matters. The rims are six lug so that matches. Idk if the rim and tire size would be to big and rub while driving..?
Old May 28, 2014 | 06:00 PM
Brian in Tucson's Avatar
Brian in Tucson
Those are going to be pretty big. Is there any chance you can try before you buy?
Usually when you go to a much larger wheel you buy like a 55 or 60 series tire. I think Tire Rack as a calculator program to help you make this decision. Try this: http://www.tacomaworld.com/forum/tir...5r15-235-60r18
Old May 29, 2014 | 02:05 PM
TheNewbie's Avatar
TheNewbie
Shouldn't be a problem. Dakota's came stock with 31" tires. The ones you are looking at are only 28.63"
Why are you concerned?
