Dropped Rocker Arm- Rotate Crank?
Old Jun 13, 2014 | 03:48 PM
Arcbc30's Avatar
Arcbc30
Default Dropped Rocker Arm- Rotate Crank?
guys, First of all I am Brian and I am new to this site. Thanks in advance for your time and help. My beloved 2002 4.7L Dakota crew cab dropped rocker arm and I am in the middle of fixing it. I have gotten down to it but I have a very rudimentary question.
What is the best way to to rotate the cam shaft so that i can install the rocker arm. I assume I need to rotate the crank pully but it looks like i may have to remove the radiator to get to it- I do not want to do that.
any suggestions would be much. much appreciated. I am hoping someone who has done this before can tell me how they accomplished it. Thanks for the help!
Old Jun 16, 2014 | 07:21 PM
00DakDan's Avatar
00DakDan
Section Moderator
How much do you need to move it? Pull the ASD relay and give it a quick blip with the starter. Or, how about a ratchet with a socket on the crank pulley?
Old Jun 17, 2014 | 08:45 PM
Arcbc30's Avatar
Arcbc30
Thanks for the input Dan. What I ended up having to do was remove the fan. Once I got that out of the way I was able rotate the crank with a 21 mm socket. With the fan in place i was unable to contort enough to get to the crank pulley, some might be able to do it without removing the fan, but I could'nt.
Thanks again
