2002 water pump and fan clutch question?
Old Jun 13, 2014 | 07:32 PM
Magimax's Avatar
Magimax
Question 2002 water pump and fan clutch question?
I can not get the bolt to break loose on the fan clutch, the connection to the water pump is wobbly. the belt driven part of the pump spins the direction that the bolt goes when I try breaking bolt loose. Can I just leave fan clutch attached to water pump and remove it all at once? Looks like I can, I have room to pull it out and replacement parts for them?
Best Regards Magimax
Old Jun 14, 2014 | 02:37 AM
Magimax's Avatar
Magimax
Default just a little support please.
I never changed a water pump or fan clutch, i can not loosen the bolt from the shaft connecting fan clutch to water pump. the shaft is only a connection of the two and nothing else. since i can not break the bolt loose can i unbolt the water pump and pull the water pump out fan clutch still attached? I have new parts to replace it all? Is it possible?
Thanks Magimax
Old Jun 14, 2014 | 05:50 AM
BlackDakotaV8_4x4's Avatar
BlackDakotaV8_4x4
Yes it is possible but you will end up spending more to get a water pump and fan and fan clutch....
Old Jun 14, 2014 | 01:19 PM
Magimax's Avatar
Magimax
Default spending more ya think?
I thought I could do it that way. TY. By the way I bought the fan clutch and water pump way before these messages Thanks trying to save me a buck.
