2000 Dakota 4.7 V8
Old Jun 25, 2014 | 09:41 PM
KillerKilgore's Avatar
KillerKilgore
Originally Posted by gtaa9
I check the check valve under the hood. I can only blow through one end...I cant blow through the other end? .........
Make sure to put the check valve back on the correct way.
You may just have a pin hole in a hose.
Had a hard hose under hood brake and I just made a splice.
You said the truck is 2000 model so hoses are 14 years old.
Look for brittle or rough hose condition on the outside of each vac hose and replace the one that need it.
I had hoses that were held together by spiderwebs.
Since you said the cruise was slow to engage
Old Jun 26, 2014 | 06:18 PM
gtaa9's Avatar
gtaa9
I changed the ac/heater control assembly and it fix the problem. Thanks a lot I appreciate the help.
Old Jun 26, 2014 | 07:23 PM
00DakDan's Avatar
00DakDan
Section Moderator
Glad you got it fixed. Question, did you get a new one or from a junkyard?
Old Jun 27, 2014 | 06:38 PM
gtaa9's Avatar
gtaa9
Junkyard...$40
Old Jun 27, 2014 | 07:15 PM
00DakDan's Avatar
00DakDan
Section Moderator
Good deal!
Old Jun 29, 2014 | 07:21 PM
cs42778's Avatar
cs42778
$40? I've been wanting a new one just because the light bulbs are burnt out on mine! Send me your old one and I'll make one good one, lol. Looks like I'm controlling mine blind at night forever now
Chad - 03 Dakota Sport Quad Cab, 01 Durango R/T, 98 Ram Quad Cab
