Valve Body Cleaning?
Old Jun 29, 2014 | 12:03 PM
Dingob's Avatar
Dingob
Default Valve Body Cleaning?
I have a 98 Dakota, 5.2, 4x4, 44re. I have no reverse and it is in limp mode. Ive dropped the pan and have a filter and sensors to replace. Theres metal sludge residue on the Valve Body and was wondering the best way to clean it without removing the vb. Should I use Brake Cleaner, Sensor cleaner? Please steer me in the right direction. Thanks
Old Jun 29, 2014 | 12:07 PM
archemedes74's Avatar
archemedes74
if it's plugged enough to stop it moving cleaning isn't going to fix it, you need a rebuild or a new trans
Old Jun 29, 2014 | 05:42 PM
Dingob's Avatar
Dingob
Truck runs and drives. What do you mean by not moving?
Old Jun 29, 2014 | 07:10 PM
archemedes74
no reverse is a sign of a bad part, the metal sludge is remnants of clutches
Old Jun 29, 2014 | 08:28 PM
Dingob's Avatar
Dingob
So do you think the loss of reverse and the sludge mean the tranny is gone. Both the front and rear bands are pretty loose but there was no chunks in the pan. The tranny was driven that way for almost a year from my understanding. I only reason I thought it was electronic/maintenance was because there is no slippage. I'd hate to scrap this thing
File Type: jpg
Old Jun 29, 2014 | 09:15 PM
archemedes74
without opening it up can't say for sure, but if you lose a gear it's not a good sign
Old Jun 29, 2014 | 09:21 PM
tspeed109's Avatar
tspeed109
Default change trans filter
I would change the trans filter with one like pro king and put in Royal purple max atf fluid. It has been known to help clear passages.
Old Jun 29, 2014 | 09:27 PM
tspeed109's Avatar
tspeed109
Default don't use any cleaner
Please don't use any cleaner. Transmission fluid is a grade above kerosene. So if u see any sludge then someone used bad or wrong fluid. At+4 is the fluid.
Just use royal purple max atf.
Old Jun 29, 2014 | 10:15 PM
Dingob's Avatar
Dingob
Ok, by sludge I meant fine metal oil residue. I was afraid to use any chemical to clean the fine metal residue off of the existing electronics on the vb. I just wanted as much advice from you experts before I complete the filter/solenoid change. Please feel free to school me if you have the time
Old Jun 30, 2014 | 09:47 AM
tspeed109's Avatar
tspeed109
Default check cooler lines
https://dodgeforum.com/forum/showthread.php?t=182742
