lower alternator bolt: 3/8-16 or M8x1.25?
Old Jul 7, 2014 | 02:22 PM
magnethead's Avatar
magnethead
Default lower alternator bolt: 3/8-16 or M8x1.25?
What the subject says- Is the lower alternator bolt a 3/8-16 or a M8x1.25? Need to know so i can pull it out and replace it with a 6.5" or 175ish mm bolt. Don't ask. The head feels real loose in a 9/16 so I'm thinking M8?
Old Jul 7, 2014 | 05:47 PM
archemedes74's Avatar
archemedes74
should be metric, very little sae stuff since early 80s
Old Jul 7, 2014 | 06:00 PM
magnethead's Avatar
magnethead
i know the body on our trucks are metric, I've dealt with both ends. Thought the motor was SAE though. Oh well, I have both bolts…guess I'll find out when i yank the old one out.
Old Jul 7, 2014 | 06:03 PM
archemedes74
only sae bolts I have on my '05 are the exhaust bolts, was the same on my dad's '87
Old Jul 7, 2014 | 06:04 PM
magnethead's Avatar
magnethead
okiedoke!
Old Jul 7, 2014 | 09:37 PM
magnethead's Avatar
magnethead
It's gotta be 3/8" It's loose in a 9/16, but I can't fit a 17/32 on the bolt (which fits an M8 13mm head). Next bump up from 17/32 is 18/32 = 9/16. Or it could be a 14mm head, but those are only used on JIS (Japanese Industrial Standard) M10 bolts, which I can't see dodge having used. Plus 14mm works out to 8.8/16, which would be fairly snug in a 9/16 wrench. Then again, I would expect a 9/16 to be snug in a 9/16 wrench too.
Old Jul 7, 2014 | 10:27 PM
magnethead's Avatar
magnethead
From THIS DF POST, looks like a great bit of the front drive stuff is SAE, so I will try to get this front drive motor put on tomorrow. Hoping it's a 1 shot thing, I only have so many spacers.
Old Jul 8, 2014 | 01:17 AM
archemedes74
mine had a bunch of 14 mm
Old Jul 8, 2014 | 01:26 AM
magnethead's Avatar
magnethead
Guess I'll find out when I yank the bolt tomorrow.
Old Jul 8, 2014 | 01:29 AM
magnethead's Avatar
magnethead
the main thing is that I can care less what wrench fits, I need to know what the threads are inside. Only way to find out is to yank the bolt.
Also, 14mm shouldn't exist. It is only used in JIS and our trucks aren't freaking japanese. Everythign should be 13 or 16mm.
