Trans problems
Old Jul 10, 2014 | 12:00 AM
scottdd's Avatar
scottdd
Default Trans problems
Changed the trans fluid and filter today, replaced filter, new fluid,gasket, cleaned pan and magnet, sealed up new fluid (4 qts) truck will not **** into any gear now. linkage is hooked up. HELP
Old Jul 10, 2014 | 12:31 AM
archemedes74's Avatar
archemedes74
were there any issue with the trans prior to changing fluid? Is the filter firmly in place? Is the fluid showing on the dipstick? 4 quarts seems a little low to me (haven't done a 2nd gen in 15 years)
Old Jul 10, 2014 | 12:56 AM
magnethead's Avatar
magnethead
Did you make sure the filter seated correctly? I know the 545RFE's (behind the 4.7) will not run at all if the filter does not get seated right. I think there was even a TSB issued for it.
Old Jul 10, 2014 | 12:32 PM
scottdd's Avatar
scottdd
Magnet--Thank you sir, you are a life saver, fixed the issue.
