Centering the wheel
Got my 04 Dak last month. The small V8 in the 2dr 4x4.
Installed a Curt front receiver and an old Ramsey 8000 lb winch that I bought new about 1980....still going strong.
Today they charged the A/C and gave it a clean bill of health.
Next project is to center the steering wheel as I notice its about 15-20 degrees away from dead ahead.
Never had a rack & pinion steering box in a truck before and I'm wondering if I should just adjust the "steering ends" where they come out of the box and keep an eye on the tire wear? The truck was owned by an old fella for the last six years until he died last fall. Probably hasn't seen any rough handling and has two sets of tires, one summer and the other winter. Neither set looks like it has any wear.....
The R&P is a moving assembly. If the tires are not wearing, it is aligned correctly. A wheel alignment does not typically include centering the wheel unless you explicitly ask for it. Even then, it may not be possible. On my truck, the tie rod on one side is just too short, and it comes apart before the wheel can be centered (also, my right side caster is unsettable….I have a very bent spindle or A arm somewhere apparently). And don't try to unhook the steering linkage, you'll break the clockspring.
Try this. It is easy to do and it worked like a champ for me when I had my truck aligned but the wheel was still a bit off center.
http://www.ramforumz.com/showthread.php?t=46601
I used a silver Sharpie to make the reference marks on the tie rod ends.
Jimmy
Jimmy
You can always just unhook your battery, wait an hour, pull the airbag fuses just to be safe and remove your steering wheel. But like Magnet said be careful or you'll damage the clockspring.
I've it on both my Mazda and Dakota, not difficult but some people don't feel comfortable with the airbag so if thats you, leave the steering wheel alone.
Trending Topics
Every alignment I've ever seen done included centering the steering wheel. They start with the wheel straight, then align the wheels so the car is going straight down the road when it's straight.
You can try adjusting the tie rods like you said, just be sure there is plenty of thread engagement when you're done. And make sure you set the toe-in correctly, or you'll get acccelerated tire wear.
Personally, I would take it to a good alignment shop and have it done.
Just had my Liberty in for an alignment at the best shop in town. Their price starts at $87. I figure I can manage a simple adjustment. I know enough not to try adjusting the wheel on a regular steering box and have built dune buggys with R&P boxes (didn't have to be precise) but this is the first PU with a R&P. Gonna try it, and then buy an alignment if needed....
