Intermediate steering shaft
Old Aug 11, 2014 | 03:40 PM
Dodgevity's Avatar
Dodgevity
Originally Posted by markk96
I just replaced mine in my 2003 Dakota. It was tough job but I finally got it. I used a Dorman replacement from rockauto.com
Watch out for Dorman... I've heard bad things about the quality of their parts. With someone as important as steering, I'd go upgraded Mopar.
Old Sep 9, 2014 | 06:04 PM
LIZZRD's Avatar
LIZZRD
Should be getting my Dorman shaft from Rock auto tomorrow.
Plan on doing this Fri. eve or Sat.
Rock is also sending along leaf spring shackles and bushings, but that will probably be put off a couple months.
Old Sep 13, 2014 | 03:46 PM
LIZZRD's Avatar
LIZZRD
Got'r done, glad a friend stopped over. It went pretty well, took my time, had to bug a 10mm socket off the neighbor, had a few beer breaks, all bolts came off easily. You can get by loosening everything and tightening up, but a helping hand getting both ends on and off should be required. My only advice would be to pay attention to the end that bolts to the steering wheel, just under the dash. It can only go on 2 ways, it's kind of oblong and the holes drilled in the old and new are a bit off center. If you have to wrestle a bolt in for half an hour ,that's when you have to turn it 180*.
Old Sep 13, 2014 | 03:53 PM
LIZZRD's Avatar
LIZZRD
I went with taking off the wheel and fender liner. I also used a smaller tool to separate the spline end, so no need for a crow bar really. I will have to get some fasteners for the liner coz most of them snapped and ricocheted around the wheel well. I also scraped and wired brushed what i could and used up some black rusteolum paint.
[URL=http://s25.photobucket.com/user/lizzrd-2/media/P1010002_zpsfe503ca0.jpg.html][IMG]http://i25.photobucket.com/albums/c51/lizzrd-2
Old Sep 13, 2014 | 04:06 PM
LIZZRD's Avatar
LIZZRD
Look at those almost gone manifold bolts ! will be checking into heat shields also...
Old Sep 13, 2014 | 07:03 PM
LIZZRD's Avatar
LIZZRD
Just want to add 1 more thing, the test drive was almost amazing. After replacing most of the front steering and suspension, this took up any slop that was left in my steering/control. Wish i had done this 2 -3 years ago. If the Dorman lasts for 10 years i'll be happy. The old was , well 18 with some road salt thrown in...
