Swaybars...
Old Oct 20, 2005 | 08:15 PM
steve05ram360's Avatar
steve05ram360
Default Swaybars...
I went to go change the sway bar bushings on the wifes truck and found that they are a massive 33mm. anyone looking to improve cornering on their ram could use this bar for sure. It is on an '02 CC Dakota... I should also add that I was un-able to find a urethane kit for it. It'll have to be a universal setup.
Old Apr 11, 2006 | 10:38 PM
twitchyfinger's Avatar
twitchyfinger
Default RE: Swaybars...
Steve,
Do you or anyone else know what size the front sway bar is on a 2000 Dodge 1500 QC 4X4? I tried the dealer and when looking up the last eight of my vin found out they just list a part# for replacemants not an actual size. I was told the sway bar is the same size from 1/2 ton to 1 ton but cannot find out what the actual size. From what I have been told it is either a 30mm or a 32mm. I am wanting to replace the cracked and worn out bushings with a urethane kit for it. Thanks in advance!!!
Old Apr 11, 2006 | 11:38 PM
steve05ram360
I got 32mm on mine. Just measured it with the dial calipers.
Old Apr 11, 2006 | 11:44 PM
twitchyfinger
Thank you very much!
Old Apr 11, 2006 | 11:50 PM
steve05ram360
your welcome... and if I havent said it yet... welcome to DF
