rear axel
Old Aug 31, 2014 | 06:47 PM
kriegs99sport's Avatar
kriegs99sport
Default free wheel to spin with drive wheel
Hey im trying to convert my 99 dakota sport 2wd from a one wheel wonder to where both back tires are goin at once what do i all need to do? not sure where to start
Old Aug 31, 2014 | 07:31 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum.
You need to find a Trac-Lock rear end OR use an aftermarket carrier. Do you have the 9.25 or 8.25 rear now? Check the cover bolts. 10 bolts is the 8.25, 12 is the 9.25. You can use either if you swap out the rear. You might have some driveshaft mods though, the pinion flange changed a bit over the years.
It might be easier to just swap out the entire rear
Old Aug 31, 2014 | 08:05 PM
kriegs99sport
i have the 8.25 . and my buddie was sayin all i needed was a locking pin?
idk he isnt all there tho either
Old Aug 31, 2014 | 08:16 PM
00DakDan's Avatar
00DakDan
Section Moderator
I don't know what he means by a locking pin.
On the factory LSD there are clutch plates that direct power to both wheels even if one slips. It also allows you to turn without damaging the tires. If you truly did "pin it" then you'd have a hard time making turns.
How much do you want to spend? What do you plan to use it for? Do you want an LSD or a true "locker" style rear end. A locker will give full power to both wheels but is only enabled when conditions warrant it.
