7mm or 8mm?
Old Sep 18, 2014 | 08:53 AM
indiglofish61's Avatar
indiglofish61
Default 7mm or 8mm?
So what would be the difference in using 7mm spark plug wires to the 8mm wires I have the 7mm, I am wondering what is the difference?
Old Sep 18, 2014 | 10:27 PM
Tom A's Avatar
Tom A
Section Moderator
With a stock ignition system, there is no difference. If you had an MSD or other aftermarket ignition, the larger wires would give you more insulation and help keep the spark from escaping.
Old Sep 19, 2014 | 09:40 AM
indiglofish61
Ok thanks that clears it up
