Sticky Situation
Old Sep 22, 2014 | 08:28 PM
NRzDwNUSqQ0GX's Avatar
NRzDwNUSqQ0GX
Default Sticky Situation
I realize this question isn't specific to the Dodge Dakota...still....
Any recommendations for removing the double-sticky tape used to adhere dorr-mounted vent shades?
So far I've tried GooGone, Isopropyl Alcohol (40%) and nail polish remover.
Thoughts?
Thanks.
Old Sep 22, 2014 | 08:43 PM
dodgeramguy85's Avatar
dodgeramguy85
Use a eraser wheel on a drill it will come right off!
Old Sep 22, 2014 | 09:47 PM
NRzDwNUSqQ0GX
Debadging - YouTube
Wait...I don't know what an "eraser wheel" is, but I DO have a Dremel tool with those soft and white buffing-type wheels (that I used to take off some of the discolored/peeling clear coat on the headlights). Is that it?
Old Sep 22, 2014 | 09:49 PM
NRzDwNUSqQ0GX
Debadging - YouTube
Like these I found at eBay (http://www.ebay.com/sch/items/?_nkw=...is=&LH_CAds=)?
Old Sep 22, 2014 | 09:55 PM
NRzDwNUSqQ0GX
Debadging - YouTube
Ok...I know this is a bit far afield, but what about taking this guy's idea (http://www.instructables.com/id/Make...Sanding-Wheel/) and using the pencil eraser on the Dremel screw-head mount? Bad idea???
Old Sep 22, 2014 | 10:02 PM
dodgeramguy85
Spend the 5-10.00 for a good eraser wheel. It will be easier in the end and much faster.
Old Sep 23, 2014 | 08:47 PM
Tom A's Avatar
Tom A
Section Moderator
This. And it won't damage your paint (unlike some home-brew methods).
Old Sep 23, 2014 | 08:48 PM
dodgeramguy85
Well it will if you hold it there for too long
Old Sep 23, 2014 | 09:00 PM
Tom A's Avatar
Tom A
Section Moderator
But you pretty much have to do it on purpose.
Old Sep 23, 2014 | 10:13 PM
NRzDwNUSqQ0GX
Recommendation heeded; did a really good job. There are still the thin lines where the double-sticky ended, but still; a huge improvement. Thanks!
