stalling in cold weather
Old Nov 14, 2014 | 08:15 PM
This guy over here's Avatar
This guy over here
Originally Posted by 00DakDan
You can have an intermittent fault in the PCM. Possibly a bad solder trace and they can be temperature sensitive.
You shouldn't be dropping communication.
So what do I do about that take apart the pcm
Old Nov 14, 2014 | 09:26 PM
00DakDan's Avatar
00DakDan
Section Moderator
Unless you have experience in repairing circuit board probably not a good idea.
Get a rebuilt one. Lots of them available online.
Old Nov 15, 2014 | 10:30 AM
This guy over here
Any chance you would b able to provide a link for a pcm. I Don't wanna spend 250 on something that is gonna die in a week
Old Nov 15, 2014 | 11:32 AM
Robertwav1's Avatar
Robertwav1
Any codes when it shuts down? When does it stall, after starting or running a while?
Old Nov 15, 2014 | 11:46 AM
magnethead's Avatar
magnethead
Do you have access to sensor data via an OBD scanner? I use the Ultragage.
Old Nov 15, 2014 | 12:49 PM
00DakDan's Avatar
00DakDan
Section Moderator
I merged the two threads.
Old Nov 15, 2014 | 01:19 PM
This guy over here
Yeah have a reader. No Codes come up nd if I leave the key on and try to start it it just cranks. I have to turn the truck completely off after it stalls and then it starts right back up first try. But occasionally I will get the no bus signal meaning it has dropped communication but I had the pcm replaced two years ago. What could be causing then to keep going bad
Old Nov 15, 2014 | 01:52 PM
magnethead's Avatar
magnethead
the ultragage gives you live sensor data from IAT, ignition timing, TPS, ect. I use it for monitoring systems.
It may be that your reman PCM is not the best quality reman.
Old Nov 15, 2014 | 04:27 PM
This guy over here
Should I start looking to buy a new one
Old Nov 15, 2014 | 04:40 PM
This guy over here
And is it possible that these things come programmed and flashed for my truck or are these websites scamming me
