Bent control arm
Old Nov 23, 2014 | 09:49 PM
magnethead's Avatar
magnethead
Just get it aligned- trust me, the upper control arm has a good 1.5" of caster adjustment. I hit the brakes hard once and folded the right front nearly into the fender because the upper control arm's adjustment bolts weren't tight.
Old Nov 23, 2014 | 10:22 PM
Josh17's Avatar
Josh17
I'll look into an alignment, but i do not think that my caster being out of spec would be the problem. The right front is sitting slightly further back than the left front. I guess they could change the specs to counteract this but i'd rather fix the problem the right way if it is indeed a bent control arm.
Old Nov 23, 2014 | 11:04 PM
98DAKAZ's Avatar
98DAKAZ
The top control arm can shift a lot on you the bottom no it has no adjustment at all I have remove them and seen how much they can get out of alignment. So it could be you just need an alignment done. Get a shop to look at it first before you freak out be warned if a shop see's you freaked out on this they may take advantage of this and give you a large estimate of work needing done. Any shop will take advantage of people freaking about anything they see you as an easy payday like most woman get taken by auto shops.
Old Nov 23, 2014 | 11:25 PM
magnethead's Avatar
magnethead
the caster controls how fore/aft the tire is in the fenderwell (It's technically the angle of the spindle, but that also effects the fore/aft placement). Like I said, there's easily 1.5" or so of play in it, so that's more than likely your issue.
Old Nov 24, 2014 | 09:27 PM
Josh17's Avatar
Josh17
I will definitely have it aligned when I get enough time away from work. And don't worry I'm not freaked out just thinking.
Old Nov 24, 2014 | 10:03 PM
magnethead's Avatar
magnethead
Lucky Caster isn't a big tire wear. Unfortunately, if caster moved, camber and toe both likely did, which can cause excessive tire wear. With that said, it is possible to have a spec camber/toe adjustment and have caster way off in no-man's land.
Old Nov 25, 2014 | 07:34 PM
Josh17's Avatar
Josh17
Yep, just like I learned in my steering and suspension class, Caster is an indirect wearing angle. haha thanks for all the advice guys.
