Bent control arm
Old Nov 21, 2014 | 11:02 PM
Josh17's Avatar
Josh17
Default Bent control arm
I hit a pretty nasty pot hole, about a week or so ago. Since then I have had a slight pull to the right. I looked at my wheels the other day and noticed that the front right wheel seems to be slightly further back than the front left. I'm pretty sure its a bent control arm. So i'm thinking of putting my truck in a shop around here to get the control arms, ball joints, front & rear shocks, coil springs and leaf springs (possibly), sway bar, and sway bar links replaced,. Basically a complete suspension rebuild. I'm wondering how much this would cost and if I should have them replace the hubs and wheel bearings as well as i have over 192000 miles.
Old Nov 22, 2014 | 12:43 AM
98DAKAZ's Avatar
98DAKAZ
You probably just knocked it out of alignment not bent anything.
If concerned have a shop or two look at it and get an estimate that will tell you more than we could just by your description. My guess is if your front end is worn out they will just replace both upper and lower control arms as that's the fastest an best option. You may need new Hubs also or just get them done to be sure this may save you some $$ as you are getting it done at the same time.
Cost just for the front around $1.5K Labor is the big cost parts alone is about $500 4 control arms and 2 Hubs most shops up charge on parts.
These costs I'm giving are a bit high as I have not had a shop do anything on my Dakota in many years I'm sure its way higher now especially labor.
DIY will save you a ton of money but cost you time down and dirty grunt work. You may want to replace your front brakes at the same time as you will have it all apart to fix the front end as long as your calipers are good the pads are very cheap.
Old Nov 22, 2014 | 12:51 AM
98DAKAZ's Avatar
98DAKAZ
Thumbs up
DIY
Look here on this forum https://dodgeforum.com/forum/2nd-gen...ta-cc-4wd.html
This one also https://dodgeforum.com/forum/2nd-gen...to-w-pics.html
Old Nov 22, 2014 | 08:07 PM
Josh17's Avatar
Josh17
I would love to do it my self, especially since i get a 50 % discount through UNOH on parts from car quest. But between having to work 10.5 hours a day 7 days a week, Class from 6:30 to 11:30 Mon-Thurs, only having a small socket set, and having no place other than a cold parking lot to do it in. I don't really have the time nor the tools to do it myself. Brakes should be fine, i did the fronts less than 3000 miles ago and the rears were done less than 1000 miles ago. I appreciate the help though. I may just take out a small loan to get this done and over with.
Old Nov 22, 2014 | 08:58 PM
00DakDan's Avatar
00DakDan
Section Moderator
A big pothole can throw off your alignment.
If you're going to rebuild the front, 98Dakaz has given you some good advice about just swapping out the entire control arm. A new arm already has the bushings and ball joints in place.
Swap all the suspension/steering parts at once. new tie rods, including the inners too. Then you'll be all set with an alignment. I wouldn't bother with the hubs unless you have a problem. You can swap them easy enough later.
You don't have to do it all at once. Do the front now and wait a bit on the rear.
Old Nov 22, 2014 | 10:09 PM
Josh17's Avatar
Josh17
Will do thanks guys.
Old Nov 23, 2014 | 01:15 AM
98DAKAZ's Avatar
98DAKAZ
new inner and outer tie rods may be one thing you could do as I believe they are easy. To get as close as possible measure them each side before removing then install new parts with your measurements they may be off some but then in a week or two have a shop do the rest.
You could do the top ball joints one side at a time as they are somewhat easy to get out or if they have been replaced before then they could be very easy to replace the top control arm bushings are not easy to do a shop would be your best bet.
I say get a few estimates form two shops find out how bad things are then get back to this forum.
Be sure they are very detailed on what is bad not just yep your front end is bad let them know you want a detailed list of what needs replacing.
No friends with a garage you could use with tools and some knowledge? beer and Pizza help.
Some city's have garages you can rent space to work on your car with tools they even supply a bit of knowledge help no hands on help. Just get a friend to go with you.
I almost forgot ooDakDan is correct about the Hubs and they are easy to replace...... usually sometimes they are stubborn and don't come out easy nothing a hammer cant help get done.
That's a start
Old Nov 23, 2014 | 06:08 PM
Josh17's Avatar
Josh17
Hmm my roommate has a decent amount of tools. I would have to see about renting a space though.
Old Nov 23, 2014 | 06:26 PM
00DakDan's Avatar
00DakDan
Section Moderator
Even the ball joints aren't that bad. If they've never been done you have to drill out or grind off 3 rivets but then they just bolt on. Maybe an hour or so each.
You don't say if it's a 4wd or not. The 2wd lowers also are riveted on. The 4wd is press in and can be a royal pain.
Old Nov 23, 2014 | 08:57 PM
Josh17's Avatar
Josh17
Its a 2wd. I think i can pay to use some shop space at the university but they don't let you use their tools, man i really need to buy some tools.
