2002 dakota 4.7L and 99 dakota 5.2 any engine parts interchangeable?
Old Dec 13, 2014 | 06:07 PM
vanillaxxgorilla's Avatar
vanillaxxgorilla
Default 2002 dakota 4.7L and 99 dakota 5.2 any engine parts interchangeable?
Hi I need power steering pump rad fan and clutch radiator and shroud
For my 02 Are any parts from the 99 Able to go on the 02
or how about rear difs can I swap out the dif off the 02 with the tranfer case and put it on the 99 any help would be great here
Old Dec 13, 2014 | 06:50 PM
00DakDan's Avatar
00DakDan
Section Moderator
Welcome to the forum VanillaxxGorilla.
I moved your post into a new thread.
The power steering pumps are different and not interchangeable.
The difference between a differential on a 2wd and that of a 4wd is the spring perch location. It's on top on the 4wd and on the bottom on the 2wd.
Transfer case? The '99 is mechanical shift and the '02 would be electrical.
