Very Odd rear end noise while making Left Turns.....
Old Jan 3, 2015 | 01:04 AM
  #81
Katmandu's Avatar
Katmandu
Originally Posted by magnethead
Agreed. I'd just get a detroit and swap your ring gear over.
Roger that. If money weren't an obstacle, I would certainly entertain a new locker rear end.
Since this is a back up vehicle, I'd be happy to find a good used Open rear end. I just don't want to be driving down the road and then.... BOOM ! What's the chances of this happening ? The rear end makes NO noise while driving straight or turning Right. Just on left turns and pulling away from a dead stop.
I'm still puzzled as to WHY the LR axle gets bound up in the first place.
"IF" the clutches are worn out, wouldn't it NOT lock up ???
Old Jan 3, 2015 | 03:14 AM
  #82
magnethead's Avatar
magnethead
Since this is a back up vehicle, I'd be happen to find a good used Open rear end. I just don't want to be driving down the road and then.... BOOM ! What's the chances of this happening ? The rear end makes NO noise while driving straight or turning Right. Just on left turns and pulling away from a dead stop.
only if they haven't crunched up and become like a shattered knee....
Old Jan 3, 2015 | 10:34 AM
  #83
Katmandu's Avatar
Katmandu
Question
Why would that happen.... and only on one side ?
Could this make my truck un-driveable at some point ?
Old Jan 3, 2015 | 10:42 AM
  #84
00DakDan's Avatar
00DakDan
Section Moderator
When the clutch plates overheat or get damaged they can break. Pieces can come off and go through the gears. That will make it undriveable. AlaskaJeff posted pics of what can happen in post #51. Worst case it can lock up and you'll spin out.
The noise or lack there of does not mean the problem is only on one side. You only hear the noise when turning left but the loads in the differential change as you turn and that can affect what is happening in the differential and the noises produced.
Old Jan 3, 2015 | 12:09 PM
  #85
Katmandu's Avatar
Katmandu
Found a great video that shows how this type rear end works.
Old Jan 8, 2015 | 02:08 AM
  #86
Katmandu's Avatar
Katmandu
I did find this very nice article on rebuilding a Ford Traction locks/Limited slip
rear end. Not exactly like the Chrysler 8.25, but still very similar in nature.
http://www.therangerstation.com/tech...tionlock.shtml
And......
Here's a video of a Dana 44 getting clutches installed.
Old Jan 8, 2015 | 09:09 PM
  #87
Dodgevity's Avatar
Dodgevity
Great stuff on this thread. It now resides on my favorites bar.
Old Jan 9, 2015 | 12:05 PM
  #88
Katmandu's Avatar
Katmandu
Question
Is there anyway to tell how many splines the axles have WITHOUT yanking them out and counting ?
Apparently, the Chrysler 8.25 uses (2) different axles. A (27) spline and a (29) spline.
Would axles happen to be different (spline count) based on if it were a 5 or 6 lug axle ?
Old Jan 9, 2015 | 12:34 PM
  #89
00DakDan's Avatar
00DakDan
Section Moderator
To the best my knowledge, '97 up are 29 spline.
Old Jan 9, 2015 | 01:18 PM
  #90
HillBillE's Avatar
HillBillE
I'll 2nd that.
I don't believe the lug count matters, it's the year.
