PO2098 check engine light code
Old Dec 18, 2014 | 04:52 PM
tspeed109's Avatar
tspeed109
Default PO2098 check engine light code
Recently my check engine light came on for PO507 Idle control system rpm high. I replaced the Idle air control but problem
still comes back. I have a PO2098 Post Catalyst system fuel bank 2 fuel trim lean.
What do I need to replace to fix these codes?
Any advice would be greatly appreciated.
thanks in advance
Troy
Old Dec 18, 2014 | 07:07 PM
00DakDan's Avatar
00DakDan
Section Moderator
Is it a 4.7, the 3.7 might be similar.
On the P0507, are you actually idling fast? On the back of the intake manifold there is an elbow - check it for leaks/cracks. Any vacuum leak will make you idle high.
That might also be related to the P2068 - don't see that much. It can be caused by an 02 sensor problem, bad PCM, an exhaust leak, or a problem with the fuel injection system.
Old Dec 18, 2014 | 07:18 PM
tspeed109's Avatar
tspeed109
Default plenum leak
I think it might be a intake leak. I already replaced exhaust gaskets. When i spray carb cleaner around sides of intake engine stumbles.
I bought victor reinz gaskets for intake and throttlebody
I also got new fuel injector filters.
When i take off plenum do i have to remove alternator. I know fuel rai has to come off.
Old Dec 18, 2014 | 07:20 PM
tspeed109's Avatar
tspeed109
Default 4.7l engine
4.7 liter engine 2004 4x4
Old Dec 18, 2014 | 08:43 PM
00DakDan's Avatar
00DakDan
Section Moderator
It does appear you have an intake leak.
You shouldn't have to remove the alternator but it give you a bit more access. You will have to remove the harness though.
